Will a 105mm Ford Throttle Body work with the stock pcm?
I bought a used C5R topend with a 105mm Accufab throttle body. Can the accufab throttle body be wired to work with the stock pcm? This will be on an drag car only running a SD tune. I thought I read somewhere that all you have to do is switch a couple of wires around and the Ford sensors will work with the stock pcm. The pcm I am using is out of a 2002 Camaro.
Ok, I called accufab and they make an IAC adapter that should convert late model gm to ford style IAC. I have one coming and will try to make this work.
The only other problem is the TPS. I know that people have been running these throttle bodies with the stock pcm. I think that some wires need to be switched to get the ford tps to work with the gm harness/pcm. I believe they are both a 5v reference.
