My diagnostics port doesn't work??!!!
Old Aug 14, 2007 | 08:22 PM
85Iroc's Avatar
Default My diagnostics port doesn't work??!!!
So my SES light came on & I was gonna hook up a friends scan tool & the diagnostics port doesn't work! WTF?? I checked fuses & didn't come up with anything. Any of you guys ever have this happen?
The problem isn't the scan tool because I plugged it into my 99 s-10 & it works perfect.
Any ideas??
Old Aug 14, 2007 | 09:01 PM
samdogmx's Avatar
check to make sure all the wiresare hooked to the back of it, i had one pull out once
Old Aug 14, 2007 | 09:08 PM
sprayjunkie's Avatar
Double check the cig lighter fuse also.
Old Aug 14, 2007 | 09:26 PM
foff667's Avatar
LS1TECH Sponsor
werd, this is the usual suspect.
Old Aug 15, 2007 | 08:10 AM
85Iroc's Avatar
ahaa! The cig lighter fuse. I didn't think about the two being connected. As a matter of fact, even though I don't smoke I checked to see if the cig lighter worked after I bought the car, just for grins, or if I wanted to plug a phone charger in, etc & it doesn't work.
I'll check that fuse tonight. I checked all the ecm/pcm fuses, but not the cig lighter. I also pulled the plug & checked the back to make sure the wires are all good.
Thanks a million guys. I hope that's the issue. Of course I was thinking the worst.
Old Aug 15, 2007 | 08:22 AM
boondiggys's Avatar
A new pcm might fix your obd2 port.
Old Aug 15, 2007 | 10:03 AM
85Iroc's Avatar
Man, don't say that ....... although it would give me an excuse to upgrade to a 99 up pcm.
Old Aug 15, 2007 | 06:19 PM
85Iroc's Avatar
Problem fixed!! It WAS the cig. lighter fuse blown. The SES light was what I expected too....... O2 sensor. So, all is good for now.
Thanks for the help.
