Shitty Drivability
TEA TFS heads, assembled
228/230 cam
LS6 chain and oil pump
caddy lifters
TFS pushrods
Harland Sharp rockers
ARP head studs
ARP crank pulley
ARP rod bolts
SLP pulley
MTI lid
XS stainless headers
no cats
true duals
Lucas 42# injectors
Anyways. I've been tuning it and getting the idle and AFR in order, and it started to get REALLY hot down here in Houston(like 150* IAT), and the car started to drive like ****. At first it would barely idle, and I figured it was because the pcm was pulling timing.
Then it started missing at WOT high rpm. Now it won't even go above 4500 rpm. WILL NOT GO, even in neutral. It's almost like im hitting a rev limiter.
It sounds very weak and missing, but it's not throwing any codes relevant to the problem.
It's pulling 15" of vacuum at idle, so I think the valvetrain is ok.
Maybe a fuel pump? How can I diagnose this?
Thanks for everyone's help.
Also, if I cold start it, the car will buck SO BAD while trying to get up to say...30, it's almost painful to my neck, and I'm not exagerating at all. Almost breaking the tires loose, the bucking is so bad.
Anyone else have any input?
Provide some more info and try posting in the scan and tune section.
I have reset the fuel trims. Thing is, I actually had the car running very well. Then it got REALLY hot in Houston and the car started to idle like crap. I dismissed this as the PCM pulling timing because of the heat. Then the idle got worse and the higher rpm sputtering and now it will sputter at any rpm and high load(WOT).
I will be putting a fuel pressure gauge on the car tomorrow. I can only hope that would be my ONLY problem. I would love to upgrade to a Racetronix PnP pump and have no more problems. Aren't they only like $230 now?
EDIT- I'm using HPT.
edit
feel free to post your tune, just keep the spreadsheets I gave you to yourself.
He has a pretty rad setup for a daily driver, I'm just trying to help him get it moving
Anyways. I did some of the changes and sent it back to you(Frost), maybe they got changed back for some reason, and that's where my problems lie. Anyways, I'm going to load my new tune and we'll see whatsup.
You loaded the file I sent you sent up for those Lucas 42s? I'm guessing so, and glad you are good to go once again.
