What is considered normal knock on LS1?
Old May 25, 2003 | 08:03 AM
Acer's Avatar
Default What is considered normal knock on LS1?
I have a 2001 LS1 powered Holden SS with quite a few bolt on mods that I have been tuning with LS1Edit. Car goes well but I have been finding lately that I typically experience ~ 2-3 degrees of knock retard in the 1700 - 2200 rpm range when accelerating in top gear at moderate throttle (typically 0.46 - 0.55 gms/cyl airflow). I have been progressively reducing the high octane table advance to reduce knock but am finding it is now back to factory settings & still knocking occassionally despite using high octane fuel & even octane boosters.
Can continue to reduce the advance angle further but as I didn't want to compromise power when the car is in other gears I am wondering how far to go. What do you guys consider to be normal knock for the LS1 engine?
Thanks
Old May 26, 2003 | 07:15 AM
Acer's Avatar
Default Re: What is considered normal knock on LS1?
Any comments or similar experience??
Thanks
Old May 26, 2003 | 03:15 PM
jimmyblue's Avatar
Moderator
This sounds like power enrichment wants fatter, to me.
Old May 26, 2003 | 10:33 PM
Badazzvette's Avatar
He wouldn't be in PE mode with moderate driving. I'm assuming that he's talking about highway driving. I'm trying to figure out the same issue with my car. I'm selectively pulling timing to see if that will help.
Old May 27, 2003 | 06:34 AM
Acer's Avatar
Badazzvette,
Your right, the engine is knocking whilst in closed loop mode & before PE comes into play. My selective reduction in timing over the last few weeks has reduced the magnitude of knock but not eliminated it. I wonder whether it has anything to do with the rate of change in advance angle as the PCM goes from one RPM/Airflow cell to another as I noticed that rapid changes during auto gear changes seem to induce knock?
Old May 27, 2003 | 09:59 AM
TaTommyWS6's Avatar
Did you try deleted Torque Management?
I had areas of "random" knock sprinkled in my logs, but after deleted TM there is hardly any...
Maybe during those "rapid changes" TM kicks in a bit? Just a thought..
Tommy
