How can I force fans on?
Old Aug 19, 2007 | 08:38 PM
Chalky's Avatar
Default How can I force fans on?
Car is 02 C5 with Code P0480. I can't see LH fan and thought I could set all fan settings to 0 and force fans on at key on. (Didn't work)
Just wnat to hear fans run and that is hard to do over engine noise.
Any suggestions?
Using EFILive!
Old Aug 19, 2007 | 08:46 PM
shoemike's Avatar
set your on temperature to a low setting {G0901} - {G0913}
and your off temperature to a high setting {G0902} - {G0914}
and lower your #1 + #2 off speed {G0920}
Old Aug 19, 2007 | 08:50 PM
Chalky's Avatar
Originally Posted by shoemike
set your on temperature to a low setting (10*)
and your off temperature to a high setting (280*)
Duh, thanks. Don't know what I was thinking!
Old Aug 19, 2007 | 10:42 PM
01'WS6's Avatar
If you are tuning via HPTuners you can force them on through the scanner as well if u dont want to mess with the settings on the tune.
Old Aug 19, 2007 | 10:55 PM
foff667's Avatar
LS1TECH Sponsor
Bi-Directional controls would be the easiest way for a temp setting, im sure live has something for this in the scanner.
Old Aug 20, 2007 | 04:00 PM
Happy Jim's Avatar
Open up the Scan tool, go to "Bidirectional" on the menu items, then select LS1/LS6 control panel.....then turn the fan on or off to your hearts content.
Rgds
Jim
