Strange LTFT problem causing stumbling, hesitation
http://www.nlcphoto.com/logs/headers.efi
http://www.nlcphoto.com/logs/headers2.efi
Thanks,
Nick
it freaks out some of the older calibrations. Wonder what you see for the
raw frequency at closed throttle decel.
You probably will find more interesting action in the STFTs, see if they
are moving a lot while the car is "catching up" from stumbling. If so you
may have a problem with decel and light acceleration being in the same
fuel trim cell but being nothing alike, maybe a VE table which doesn't
cover the MAP dimension very accurately. Not too many people try to
tune deceleration and it may "taint" the fuel trims for a bit after.
Make sure you have decel putting you in a different fuel trim cell
than your cruise and acceleration closed loop.
If you have an active deceleration fuel cut, and push very little
exhaust, your O2s may be pretty sleepy and push trims on that
basis (false trimming).
