Crankshaft variation learn BS!!!
But anyways, back to the topic. Deleting the 1336 doesnt hinder performance. Furthermore, turning off the code, that is "no error reported" doesnt keep the system from detecting misfires. So, as for your first comment about keeping your car in "proper working order", by deleting the code, you arent doing anything thats keeping your car from being in "proper working order".
The misfire detection is only inhibited above 1000 rpm only when the dtc is set.
So, if its not set, you still have misfire detection capability.
And, sure, a Vetronix/TechII/MasterTech is nice to have... if you have a means to afford one.
When someone posts something like you'd be just as good stickin your hand up a chickens ***, and then is wrong on top of that, I'm gonna call em out. ESP, when one of the people that person is referring to is ME.
You do need to have the wire that goes from the brake light switch to the PCM connected in order to do the crank re-learn.(purple wire if I remember correctly)
No replacement for OE tools/software.
Edit: correct pin location. Wrong about it grounding.
Which is why I was leaning toward's checking the sensor's and wiring.
The CKP does a learn of all the variance's in the reluctor wheel and all it's sensitivities as it wears down. The crank relearn is done so the PCM will know the relation of the two for misfire detection like Ed said.
I would post that info up but it's ford specific and wouldn't do you guy's any good.
