Preadator programming not allowing WOT
Old May 28, 2003 | 11:47 AM
JeremyF's Avatar
LS1TECH Sponsor
Default Preadator programming not allowing WOT
I data logged a buddies car the other day, an 01 A4 vette with some boltons and to my amazement It did not allow him to go wide open throttle through the mid range of his powerband. I first thought he was being a soft peddle but i see him drag @ the track all the time. So he let me drive it and EFI live doesnt lie, I went WOT and the prog cut throttle % when I went from 3500 to 5200 by as much as 22%. What I found in the code was that they had limited the torque to 360. So whenever the PCM is estimating over 360LBS TQ it would cut TP% to limit the TQ. I reflashed the computer and fixed the problem with LS1 edit.
JUST THOUGHT ID STIR THE POT.
