Is It Possible?
Old Sep 9, 2007 | 10:58 AM
Ego Killer's Avatar
Default Is It Possible?
To mix up the cam sensor and the map sensor plugs in the back on the motor? becouse I just did a motor swap and when I try to start it it just dumps gas and fauls the plugs..I kinda blamed it on my tuner becouse I went from 26# to 42# I was thinking he might not have scaled my injectors right..the car is also throwing a mult. misfire code
Old Sep 9, 2007 | 05:45 PM
trans am1's Avatar
ok did not know that
Old Sep 16, 2007 | 11:12 PM
Ego Killer's Avatar
just for the record you can not get those mixed up they look alike but wont interchange
Old Sep 17, 2007 | 12:02 PM
fast377's Avatar
Get a dyno tune!!! Your new setup is way more radical than your old one. But the mail order tune should have taken care of the injector part (those are easy to scale). But if some other table(s) is out of whack, you will still run pig rich. Don't know about the multi misfire though. Probably just the huge cam and stuff screwing with the computer. Make sure everything is plugged in (grounds too) and put some new plugs in it. Then get ready to send the computer off a few more times.
