Injector Driver failure
Old Sep 12, 2007 | 10:57 AM
AutomagicLS1's Avatar
Default Injector Driver failure
If you have an injector driver failing or failed I dont know how many are in the pcm what are the symptoms if ones acting up or completely gone?
Old Sep 12, 2007 | 12:24 PM
01WS6/tamu's Avatar
Put a noid light on the ailing injector connector and it should flash when you crank the motor and tell you if you are good or not. Then check for 12 v at the injector connector and then use a voltmeter to verify there is not an open circuit between the pcm and the injector by putting it on diode check and hooking up the lead at the injector side and then on the pcm side with the pcm disconnected, the meter should beep and give the resistance of the wire you are checking. If all checks you either have an injector shorting and the pcm is shutting off the affected driver or a pcm failing.
Old Sep 12, 2007 | 01:14 PM
Ok I will try that but the voltage is scaring me you posted already. I used a volt meter with the engine running on some of the injector harnesess and some were at 8 volts a few were at 4 volts idling and that was producing 650 degree temps at the primary on the header off that cylinder
Old Sep 12, 2007 | 01:49 PM
jimmyblue's Avatar
Moderator
The injector duty cycle would produce something between 0 and 13V
directly across the injector. Close to 0 at idle. You need to be careful
with digital meters, sometimes high frequency AC is not averaged like
old analog ones. But you would expect the voltage to be consistent
at idle with fixed RPM & MAP.
A failed driver will most likely fail open (no voltage across injector) or
shorted (full IGN voltage). If it's somewhere in the middle then the
driver is switching so probably close enough to right.
Old Sep 13, 2007 | 02:12 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I'm not sure what symptoms you have or what sparked the concern, but I have seen people have injector issues after installing a tranny. The problem was that they pinched the injector harness when they tightened up the dipstick tube. It may be a long shot, but it's a thought.
Good luck!
