Knock Sensors
To get straight to the point, one of my knock sensors is toast. Had to relocate them to the sides of the block with my 427 transplant. The left bank knock sensor was about 3-4 inches away from the headers, but somehow it still had a melt down, so I'm down one knock sensor. My question is will this affect the operation of the other knock sensor and cause it to not register in the pcm, or will the other one still function until i get the other replaced?
Thanks a lot,
Adrian
Thanks,
Adrian
Thanks,
Adrian
Thanks again,
Adrian Mejia
PS, I am not using the PE table. Using the PE table is sort of like a middle man to the final commanded AFR. So, I'm just using the Commanded AFR table in this case. I've never had a problem with it before, so really the PE table isn't needed.
Thanks again,
Adrian Mejia
YES IT IS. Unless you have fully manually disabled it, it dictates fueling for heavy throttle. If you HAVE disabled it, I'd like to know how you achieve WOT enrichment.
And, back on topic, any concrete yes or no on the knock sensor issue? If one is disconnected will the other still register and work?
TIA,
Adrian
Yes there are many ways to skin a cat, but I don't see the merit in this method for MOST people.
As far as the deal with one sensor going bad; it should still set a code (like low voltage) but from looking at my own car, I don't think it takes action (pulling at PE) until BOTH are bad.
Yes you are correct, I am talking about that table. It is true that OLSD can be rough, but tuned properly can take a lot of headaches away from a regular CL setup with a larger cam or like you said, race setup etc.. I'm also running a custom operating system through EFILive which allows for fueling adjustments to be made according to different IAT, plus TPS vs RPM VE tuning capabilities, which at that point, have made my large cammed 427 run nearly stock if not better.
Sorry i was late to respond, been gone on mission for the past 3 days. So, what your'e saying is that as long as one knocksensor is running it'll detect knock until both are no longer functioning or I enter PE mode?
Thanks,
Adrian
I'm sure to what degree one sensor will cover. I do recall that on my own ride, it didn't start pulling timing whenever in PE until both died. Sorry.
