pcm unused 5 volt inputs
Old Sep 21, 2007 | 10:15 AM
mterveen's Avatar
Default pcm unused 5 volt inputs
on an 01 pcm what unused 5 volt analog inputs are available? i assume the egr from what i've read. i have removed the air pump system and rear o2s also. i would like to hook up my wideband to 1 and / or a fuel pressure sender to another.
has anyone purchased just a fuel pressure sending unit and tied it into the pcm for logging? if so do you have a writeup on hardware and procedures?
thanks.
Old Sep 21, 2007 | 10:25 AM
Doc's Avatar
Doc
http://download2.efilive.com/Tutoria...20Tutorial.pdf
Old Sep 22, 2007 | 10:44 PM
mterveen's Avatar
Default fuel sender hookup
thanks - thats perfect - how about a source for the female/female connector?
also - what, if any, are the other 5 volt analog sensor inputs available in the pcm? i don't think i want to use the map sensor since the engine is always using it. also i see that the a/c can be used but i think that requires a switch to disable the a/c side. does the pcm constantly monitor and use the fuel tank pressure sensor or can i switch it to use the new fuel sender? what actually does the fuel tank pressor sensor do?
Old Sep 24, 2007 | 10:37 PM
mterveen's Avatar
Default fuel tank pressure sensor
anybody have any insight for me on the fuel tank pressure sensor? does the pcm need it to run or can i used that for my fuel pressure sender?
Old Sep 25, 2007 | 09:42 PM
Jditlfm's Avatar
Maybe for evaporative emissions? So when the tank gets to a specific pressure it knows when to vent the carbon canister or purge it. Im not sure at all but am just taking a guess at it.......
Old Sep 26, 2007 | 08:54 AM
mterveen's Avatar
Default fuel tank pressure sender
ok - since i am either asking a dumb question or nobody knows the answer let me suggest an answer. as jditlfm proposed, i assume the fuel tank pressure sender is used in the evap system to purge fuel pressure out of the tank. since i am removing all the evap stuff including the solenoid this should free up the fuel tank pressure sender pcm wiring to use as another 5 volt input into the pcm. my plan is to used the egr wiring for my wideband and the fuel tank pressure sender for my fuel rail pressure sender so i can log both easily in hptuners. sound correct?
Old Sep 26, 2007 | 10:20 AM
edcmat-l1's Avatar
Yes the tank pressure sender is for the evap emissions. Its actually a negative pressure sensor, and is used to determine if there is a vacuum leak in the evap/purge system. If you are deleting the emissions, you can use the circuit for your fuel pressure.
Old Sep 26, 2007 | 10:30 AM
Doc's Avatar
Doc
You can use a GM/Delphi ECT sensor pigtail to hook up to the autometer sending unit shown in the link I posted.
Old Sep 27, 2007 | 12:11 AM
mterveen's Avatar
Default wiring harness
thanks doc - i called autometer and they said the harness to use is 5227 and not 5223 (its also about $15 cheaper). is the harness you reference above the same as the 5227 (i.e. it will fit the autometer sender? and if so what is the part number)?!
so i am getting an autometer 2246 sender, 5227 harness, a 1/8 npt female to female coupler, and a 4 an female to 1/8 male npt adapter.
will wire it into the fuel pressure tank sender pcm lines
will wire the wideband sensor into the egr pcm lines
Old Oct 4, 2007 | 09:30 AM
mterveen's Avatar
Default pin outs on sender
before i finish the wiring install can someone confirm for me the pinouts on the autometer pressure sender. there are 3 pins arranged as follows:
0 0
0
i assume they are for 5v power, chassis ground, and sensor signal. can someone confirm which pin does what? thanks.
Old Oct 4, 2007 | 02:52 PM
mterveen's Avatar
Default autometer sender pinouts
straight from autometer. i only included the sender side - not the harness.
black = ground
grey = 5v ref
purple = 0-5v sensor signal
Old Oct 17, 2007 | 12:30 PM
BANDIT8's Avatar
Are you referring to the Delphi part 1997278? It is connected to the fuel rail and runs into the manifold?
Old Oct 17, 2007 | 07:23 PM
VH5150's Avatar
Dynojet Fan
black = ground
grey = 5v ref
Looks like youre on track...... Dont forget to do a custom pid and get the particulars on the sending unit....
