Independently Tested INJECTOR FLOW NUMBERS!!!
Old Sep 24, 2007 | 02:31 PM
DVCrazyCamTAWs6's Avatar
Default Independently Tested INJECTOR FLOW NUMBERS!!!
This has test pretty much every injector we are all using; they have sorted them by part number and make
they have tested these injectors all at 43.5psi of an accurate comparison between the injectors
this may solve the unknown flow rating for some SVO injectors some of us are using
http://www.witchhunter.com/injectordata1.php4
Old Sep 29, 2007 | 12:32 AM
pkincy's Avatar
Excellent data.
Unfortunately they don't have data for the part nos in most of the controversy....the Ford SVO 30#ers (M9593-B302F).
Please see this link from FordRacing.
http://www.fordracingparts.com/parts...tKeyField=5772
the first time (in a long time) I have seen the flow pressure used for the flow rating published......40 psi.
Perry
Old Sep 29, 2007 | 01:27 AM
Goldfinger911's Avatar
I have those exact SVO injectors (set of 8) and the number on the side of the housing matches this one. http://www.witchhunter.com/flowdatapix/b0280150945.jpg
What really confuses things is 312cc is slightly less than 30lbs of fuel and it was tested at 43.5psi? Oh oh... the controversy continues.
The thing that confuses me is the power people have put to the ground running SVO 30# injectors is more than they really should, according to the injector sizing tools out there.
