FAST vs. big stuff 3 opinions
heres a good deal on efilive and a roadrunner. FWIW
https://ls1tech.com/forums/lsx-parts-sale/785481-road-runner-efilive-v1-2-sale.html
https://ls1tech.com/forums/showthread.php?t=785481
Big Stuff is also a great peice.
The XFI requires the use of an external box called a XIM which is an electronic distributor and is needed for running coil on plug ignitions
The Big stuff does not require this as it is built in.
I am told though when using it for a coil on plug setup you lose
some other functionabilty.Im not sure what though.
Making as much power as you should,I would personally go aftermarket ECU.
Let me know if you need anymore help.
BTW where are you located?
the roadrunner does not.
Yeah but $@&# tuning 150lb injectors with an OEM based platform...
I haven't used or even seen the innerworkings of the fast setup but BS3 is nice and has tons of other advantages over a modified stocker like the RR. Closed loop wideband control at selective times is nice. Fueling and timing based on it's own native wideband is nice.
