Idle/VE tuning order
Old Oct 2, 2007 | 08:18 PM
nikon1999's Avatar
Default Idle/VE tuning order
Hey all hows it going..
Had a question for yeah, i've been trying to get my start-up/idle dialed in, but in between waiting for cold starts i was hoping to work on my ve. I loaded up a VE tune tonight to go log and the car oscillated from 800-1200rpm idle and the AFR commanded was 11.1:1 !! Could this be because my RAF isn't dialed in yet or is something else wrong. Could my VE be WAY to rich on start up right now and o2's/maf are just compensating? Heres the log
Thanks for your help
File Type: hpl
Old Oct 2, 2007 | 08:27 PM
edcmat-l1's Avatar
I cant view your log from this 'pooter, but I can tell you if you're trying to dial in your VE your MAF should be off, so it shouldnt be compensating if it is.
Old Oct 2, 2007 | 10:03 PM
nikon1999's Avatar
i kind of missed the obvious with that statement, i have it in SD as im throwing the po103 code and maf fail is at 0hz... O2's should be off as im in open loop, i guess it has to be my VE throwing it off? but how could it be off so much, and run ok w/my regular tune
Old Oct 2, 2007 | 10:16 PM
edcmat-l1's Avatar
Post or email your tune and a log. You can email it to me. Send me a pm. I'll look at it tomorrow. Gimme a run down of the car too.
Old Oct 3, 2007 | 05:46 AM
nikon1999's Avatar
Here's the tune i used for VE tuning aswell as the log of when i tried to get it going. The car has untouched 205 heads and a mid 230's cam with a tad over .600 lift on a 112 lsa. Thanks
File Type: hpt
File Type: hpl
Old Oct 3, 2007 | 07:47 AM
edcmat-l1's Avatar
Your MAF is still active. Zero out the table. Set the other codes to no MIL. Remember too, that the secondary VE table needs to have the same values as the primary, in each specific line.
The VE tables look pretty much untouched. You can start by multiplying the 400 and 800 columns by .9 and that will get you a little closer. The rest of it looks like you got it set up to SD tune. Do you know how to use your histograms?
PM if you wanna.
The MAF is active in your log too.
Old Oct 3, 2007 | 11:35 AM
nikon1999's Avatar
zero out the maf/freq table? I thought you just had to set the fail to 0hz. I spot checked the secondary and primary and they looked the same, but i will double check. In terms of histogram use i've been pulling configs off hptuners.. I know its histogram #7 i want for VE.. At first it wasn't working, but thats cause i wasnt logging commanded AFR, which i added. I will double check all those things and let you know how i make out. I will just straight up unplug the maf
Old Oct 3, 2007 | 11:51 AM
edcmat-l1's Avatar
You dont have to unplug it, just zero the table. Look at your log. The maf is still active. When you zero the table, in your log the MAF will be zero.
As you make changes to your primary VE, cut and paste the lines you need into the secondary. Copy with labels never works for me for that.
Old Oct 3, 2007 | 09:53 PM
nikon1999's Avatar
well i unplugged my maf entirely and im 99% sure my tune is setup correctly for OLSD VE tuning via WB. I did some logs and my fueling was way off across the board, -20. Did the changes then it was lean, did the changes then its rich. I'm still at -10, -15...etc Is this common or am i doing something wrong? I've been making changes to secondary ve only until i get it squared away then i'll do primary, as its a 99 model year car.
My first ve log, and the last one i did. If anyone has any opinions please chime in. I should still see STIT values correct?
File Type: hpl
File Type: hpl
Old Oct 4, 2007 | 09:38 AM
edcmat-l1's Avatar
NO. You need to copy/paste special/multiply by 1/2 to the primary table. Then, copy/paste the lines individually to the secondary. Its the only way to dial it in correctly. You CANNOT do one table or the other and expect it to work. That is way you're swinging from way rich to way lean.
Start over, with your stock tables, do the primary, copy over the lines to the secondary, then repeat.
Old Oct 4, 2007 | 11:51 AM
LS1INSIDE's Avatar
You could also make a histogram for your secondary table as well takes all the work out of coping and pasting 10x
Old Oct 4, 2007 | 12:48 PM
edcmat-l1's Avatar
DAMN That makes sense!! I'm an idiot!
Old Oct 4, 2007 | 02:36 PM
LS1INSIDE's Avatar
lol, your not an idiot.
Old Oct 4, 2007 | 05:11 PM
ThirdGenLS1's Avatar
i have usually found almost all idle issues can be solved with adjusting spark/fuel/raf. I decreased my ve table below 1200 by about 35%, upped the timeing, and ran raf, and the car now idles perfect.
Old Oct 4, 2007 | 08:54 PM
nikon1999's Avatar
idle isn't my problem at this point, that i have pretty much perfect I was just questioning my VE tuning, but it seems i was doing things a bit roundabout.
I already figured out making a secondary ve histogram, that i figured out after cutting pasting every other line the first time.
After one night of playing the car is almost a dream to drive, 100x better than it was.
