Truck vs FBody
My situation...I am planning on swapping a T-56 into my 00 Tahoe and ideally would like to use an ECM with an 00 Fbody VIN burned-in and the Fbody maunal harness. I already run Fbody injectors and I hope that the coil pack connector is the same. I want to get the separate IAT sensor.
The various tuning programs appear to be different for trucks and Fbodys, at least they claim to sell different versions for each. Is the hardware the same or are there subtle differences? I believe the PIN assignments may differ at the ECM or am I wrong?
I am going to be doing significant SD tuning anyway so I'm not too concerned about the stock Fbody tune. There should be very minimal if any controls on the T-56 from the ECM. Gearing and tire size can be changed.
Do I lose my gauge cluster? Maybe ABS?
Anybody have any experience or thought on this?
the same PCM P/N and OS (Express van, non-HD pickups and F-body).
Trucks seem to have some "duty" based differences. There was the
tow/haul ("Performance" mode in trans settings) switch, PE is held
off a while and ramped in slow (bad for performance, meant for
towing fuel economy I guess), burst knock retard is over-eager and
will steal performance in lower gears, etc.
Pick up the '01-'02 OS as it has a few niceties over earlier ones.
Couple more questions:
1) Can this transmission egment swap operation be completed with Edit?
2) Does a manual trans harness from an FBody directly swap over to a truck (plug & play)?
Do you have any info on the t56 conversion? We can't find much.
