diablo ?
Old Oct 14, 2007 | 09:29 AM
ws66's Avatar
Default diablo ?
Ok I am putting a MS4 cam in and headers with offroad y-pipe and bumping my no2 up to a 150 shot now my ? is when I put the cam in can I tune it with the diablo so it doesnt throw codes and runs right and with the rear o2's can I delete them and than when I put the 150 shot in is there anyway to retard the timing so I dont burn my pistons up but can I run the car w/o no2 on the retarded timing oh yeah I am either porting my maf or buying the slp would that effect anything to I also might be porting my tb
thanks Joe
Old Oct 14, 2007 | 03:46 PM
ws66's Avatar
anyone?
Old Oct 15, 2007 | 02:08 PM
sprayjunkie's Avatar
Pulling timing, no problem.
Deleting the rear O2s, no problem.
Now, that cam will require a custom tune no matter what.
Even if by some chance the car will start and run, it will need help via tuning.
Your best bet is to contact a CMR dealer that can make you a custom tune that can be loaded into your Predator and tweaked on the dyno.
Old Oct 15, 2007 | 07:46 PM
ws66's Avatar
ok so when I have this custom tune made can I have them retard the timing or do I have to do it?
Old Oct 15, 2007 | 10:15 PM
sobaka__79's Avatar
Yea get a tune,
In the mean time, you can up the rev limiter to 6800 or whatever for your cam.
Set your injector slope to -25 or -30 and increase your Power enrichment to positive 27 or +30 somethin
You can pull timing (spark) when u go to the track to spray, pull 8 to 10 percent if your on a 150 shot
Also wait till you throw you codes, then tune them out
Old Oct 15, 2007 | 10:23 PM
sobaka__79's Avatar
Get a timing tuner to pull timing when you spray, like from harrisspeedworks or the likes.
That way u don't compromise your na tune for the spray
Old Oct 16, 2007 | 03:42 PM
ws66's Avatar
ok cool thanks for the help
