idle relearn procedure?? where to find?
Old Jun 11, 2003 | 08:24 AM
SB's Avatar
SB
Default idle relearn procedure?? where to find?
Search features does not work so does anyone know where to find the idle relearn??
Thanks,
steve
Old Jun 11, 2003 | 10:22 AM
Catskynr's Avatar
Default Re: idle relearn procedure?? where to find?
Idle Learn Procedure
Automatic Transmission
1) Turn OFF the ignition.
2) Restore the PCM battery feed.
3) Turn OFF the A/C controls.
4) Set the parking brake and block the drive wheels.
5) Start the engine.
6) Ensure that the engine coolant temperature is more than 80°C (176°F).
7) Shift the transmission into Drive.
8) Allow the engine to idle for 5 minutes.
9) Shift the transmission into Park.
10) Allow the engine to idle for 5 minutes.
11) Turn OFF the engine for 30 seconds.
Manual Transmission
5) Place the transmission in Neutral.
6) Start the engine.
7) Ensure that the engine coolant temperature is more than 80°C (176°F).
9) Turn OFF the engine for 30 seconds.
Old Jun 11, 2003 | 12:17 PM
Team ZR-1's Avatar
The idle procedure seems to have changed from year to year but I go by the one I have which includes adding 5 minutes Idle with A/C on full blast so that idle trim cells 17 and 18 also get calibrated after idle no A/C was done.
This then gives a full ten minutes of idling allowing one cycle time of PCM reacting to LTFT values.
Old Jun 12, 2003 | 07:43 AM
SB's Avatar
SB
thanks, guys!
steve
Old Jun 24, 2003 | 07:07 PM
Quickin's Avatar
I just did the idle relearn procedure because right after I changed my plugs and wires last week, the motor would idle up and down like crazy everytime I came to a stop at a light or whatever. The rpms would jump from 400 to 1,500 rpm and sometimes stall.
After the procedure it's pretty much back to normal, but it still wigs out like that on occassion.
Does the PCM need time to learn it all the way????
Thanks
