LS7 Swap/Crank Relearn
Old Oct 25, 2007 | 09:58 PM
red91z's Avatar
LS1TECH Sponsor
Default LS7 Swap/Crank Relearn
I have a friend that put an LS7 crate engine in his 69 camaro. The engine is bone stock except for the swap headers and air cleaner assembly. The car has a slight surge and occasional bucking at lower rpm cruise speeds. It is setting a crank relearn code but the GM dealer says the ecu looks for a brake switch signal and without it the tech will not do the relearn. Has anyone else gotten around this or have any ideas?
