What to tune for LTRIMS when MAF tuning doesnt work
Im just new to that table which was why im asking questions. Its similair the the MAF table, except to richen you mult by say -99% and to lean you MULT by 101+% Trending Topics
My Approach to Fuel Tuning with LS1-Edit
http://www.blackls1ta.com/LS1-Edit_Tuning.htm
If you change the injectors, you modify the IFR table to reflect the change of injector flow rate,,
If you make a change involving the flow thru the MAF, then you change the MAF table to reflect the change.
I cant understand how someone would multiply the MAF table by 134% because the fuel injectors were changed?!?!?!?!?!?
Case in point: I just changed my stock injectors for MSD 30#/hr injectors. With Ls1Edit, I changed the injector table by 114%. Everything runs just great.
Case in point: Last year I changed the stock MAF out for a GMAF,, then I made several ATAP runs and determined the appropriate change to the MAF table because the GMAF has different flow characteristics than the stock MAF sensor.
