Went to the dyno today
Old Nov 1, 2007 | 10:24 PM
JESSIE's Avatar
Default Went to the dyno today
I went to the dyno and put down a best of 387.7rwhp @ 6400 and 362.2 ft lbs @ 5100
I just got HP tuners and am trying to figure this out. My air fuel ratio was pretty rich on the first couple of pulls I leaned it out by reducing the PE. I was able to get a pretty flat smooth afr around 12.9-13.0.
I started to mess with the timing and incresed it from 28 to 33 degrees in 1 degree increments I didn't see any loss of power and no knock.
I thought I should have gotten more power do you think I should take out some timong or leave it at 33 degrees. Any advice. I am goign to the track on Sunday and will play with it some more.
Old Nov 2, 2007 | 01:22 AM
chevyls10's Avatar
take that timing back out, you hit the threshold of power increase. Also it will safe guard you for later if you get some crappy gas or if your tune is rough under other conditions.
Were those numbers while the TNT kit was spraying? If so that is a little lean and I cant believe it wasnt knocking
Old Nov 2, 2007 | 03:53 PM
JESSIE's Avatar
no that was all motor no spray. I lower the AFR to around 12.4-12.5 and take about 4 degrees of timing out on the bottle.
Old Nov 2, 2007 | 05:37 PM
chevyls10's Avatar
nice hp numbers then but you should take that timing out since it is not doing anything for you. Although 28 degrees on the top end sounds high already but if it works then awesome
