SES error and inspections??
took it and got the code retrieved and found out it is a bad bank 1 (drivers side??) catalytic converter. drove the car home and reset the computer and light went out. after reading the stickies, it says i still won't pass testing? something about going thru several heat cycles. if i do this, will it pass? provided of course the light does not come back on?? or is replacing the cat the only fix? if that is the case i believe instead of money on a cat i will just go ahead and get some emission headers and catted y pipe. any info/advice is appreciated. thanks
jman
not sure how the nc tests work, i moved here from florida (as you know, no tests) and my previous nc vehicle was a 94 and they don't emission test the cars before 95.
oh, and i just reset the pcm (unhooked the neg battery cable)
should i take it to the stealership er i mean dealership??
thanks again for any help/suggestions
jman
thanks for your help
gearchatter is where i was reading. i will wait a little bit, just need to avoid any check points or speeding tickets for a few weeks. i drive a company vehicle monday - friday so i only drive the WS6 on the weekends. i guess if it comes back on take it to a dealer and see if i can get the cat replaced? damn testing!
if i still lived in orlando i wouldn't care. i would just grab some headers and an off road y
thanks again
