MAF Translator ?
Old Jun 16, 2003 | 02:30 PM
2002ScottOnyxSS's Avatar
Default MAF Translator ?
I am using AutoTao and MAFT on a 00 Camaro SS...
Is each subsequent MAFT BASE percentage based on the original (nonMAFT) factory settings or the previous average.
In other words do I calculate my next adjustment based on the previous average or the value obtained at MAFT=0?
Same question with the WOT settings.
Thank you,
Scott
Old Jun 16, 2003 | 03:14 PM
Mike's 01WS6's Avatar
Default Re: MAF Translator ?
If you used atap and then adjusted it and it still wasnt right then you would atap it again and adjust it from where ever it was when you used atap.
Old Jun 16, 2003 | 07:45 PM
WS6 GreeN's Avatar
I'm not understanding your question completely, but you adjust your BASE until your LTRIMS are negative. Adjust 5% and if that doesnt fix it, adjust 5 more percent. Continue doing this until your LTRIMS are right where they should be.
Old Jun 17, 2003 | 01:37 PM
gotcha - thanx for the feedback
