ls1edit file for 4.10 gears and 26 inch tall tire.
anyone have a file from a 2000 car that I can look at the shift settings on? I cant get mine to shift right.
1-2 shifts fine but 2-3 shift happens as soon as it goes into second.
Thanks in advance,Brent
brentb3243@comcast.net
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Go here and do a search by year/platform. There are several to choose from.
http://www.ls1edit.com/filelib/
-Andrew
-Andrew
I don't know if this will help but go here and enter the information below.
http://www.f-body.org/gears/
4.10 axle ratio, 26 inch tire, pick your redline rpm (I put 6800 just for kicks, all you'll need is your desired max rpm). It will show you the mph at which your engine will be at xxxx rpm. You should be able to use those numbers to enter into Edit. I'll find out next week when I try to program my car. I will also have 4.10 gears with the 4L60E and 26" tires.
BTW, Gear ratios for the 4L60E:
1st-3.059:1, 2nd-1.625:1,3rd-1:1,4th(OD)-.696:1
I'll be using the mph that corresponds with 6200 for now because I still have stock internals. In another month or so I'll be installing the C1 cam and I'll probably spin to 6600. Maybe next Spring I'll get a set of Stage 2 heads and spin to 6800. I'm hoping the 4.10s will be kick **** with my set up.
Hey, since we have very similar set ups, let me know if you find a file that works well. Also, will you ever change cams? I'd like to see what changes were made on Edit for the cam (idle, IAT, spark advance, etc.)
Good luck!
Derrick
Good luck!
Derrick
I am on my third cam
Thanks I will try that if that doesn't work it has to be the trans.
engine tuning part is easy once you tuned for base. (either through maf or or inj offset)
email me if you need any help with that.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
