Gauges problem revisited
Old Nov 6, 2007 | 11:21 AM
fast377's Avatar
Default Gauges problem revisited
This is the last of the bugs I have to work out on my swap (well this and an oil leak). The car is a 91 Z28 LS1/t56, dash and all wiring out of the donor car. The problem is my oil pressure gauge is maxed out, and my fuel level is bottomed out. I checked all my grounds and fuses, and they all appear to be fine. I have cel codes u1000 and u1301 (which for some reason you can't turn off).
According to the wiring schematic for the instrument cluster, oil pressure signal comes from the pcm and fuel level comes from class 2 data. The u1000 code is a class 2 communications error, so they may be linked (but abs, sir, and some other stuff (which I don't have) are also class 2 data stuff.)
Where is this problem coming from? Would a bad ground effect only those two gauges?
Also, on the ls1 fbodies, there is some sort of module mounted on the bottom side of the driver side frame rail (kind of below the abs stuff) that I am not using. I don't know what it is, and I can't find anyone that does. I don't mind that it is not there, I just want to make sure it isn't causing any problems.
Old Nov 8, 2007 | 03:26 PM
fast377's Avatar
No ideas?
Old Nov 8, 2007 | 05:39 PM
ryansm1's Avatar
What did you pull the PCM/harness/engine from? The F-bodies don't have a functioning oil pressure PID in the PCM as the signal from the OPS goes straight to the cluster.
I've attached a schematic for the instrument panel (thanks to joecar from EFILive forums for the image). Fuel pressure is class II, like you suspected.
FWIW, I have seen some bad oil pressure senders peg out at max pressure. Have you tried it with a known good sensor?
Old Nov 8, 2007 | 05:49 PM
98Camarod's Avatar
Oil pressure could be either a bad unit or a broken one. I'm not too sure about the fuel gauge. Do you have a signal before the gauge?
Old Nov 8, 2007 | 07:19 PM
fast377's Avatar
Thanks for the replys guys. ryansm1, that is the schematic that I have been going by. The PCM and engine harness are out of a 2000 Z28, while every other harness (bcm is out of a 1999 Z28) are out of a 2001 Z28.
98camarod, I haven't checked the ops output before the instrument cluster, nor do I know for sure that the ops is good. I'll pick one of those up and try it. Now I did check the fuel level with hptuners...problem is, I ran it out of gas, but it did say I had .5gal, so maybe that problem could be instrument cluster related.
Any ideas about that module on the frame rail? I would like to figure out that u1000 code...but like I said, that could be from the lack of abs and air bags.
Old Nov 8, 2007 | 07:27 PM
98Camarod's Avatar
I'd say you are probably right about the abs setting the code. I'll look for the module tomorrow and see if I can help you out. It's pretty dark outside right now
Old Nov 8, 2007 | 09:52 PM
fast377's Avatar
That would be great...thanks a lot!! It's kind of driving me crazy not knowing what that is.
Old Nov 8, 2007 | 10:50 PM
felton316's Avatar
I know if you leave the oil pressure sensor disconnected, it will read maxed out. Maybe you are not completing the circuit somewhere?
Old Nov 10, 2007 | 11:58 AM
fast377's Avatar
Which class 2 module (and where is it) does the fuel pump signal run through before it goes to the instrument cluster?
