SD tuning question
Old Nov 21, 2007 | 09:18 AM
MikeC5Vert's Avatar
Default SD tuning question
When doing SD tuning, is there any MAF parameter that needs to turn off?
Can the MAF be completely removed?
I am re-doing my supercharger installation and if the MAF can be removed, I will fab the air-bridge longer.
Thanks in advance!
-Mike
Old Nov 21, 2007 | 09:29 AM
edcmat-l1's Avatar
Set the table to zero. Set the MAF fail in Engine diag to zero. Set the MAF codes to no SES. Copy the high octane spark table to the low octane spark table. You can unplug it and remove it, but if you've got a 5 wire maf it has the IAT intergrated. You'll need to convert it to a seperate IAT. You'll need a sensor and a connector. I think a few companies sell adapter harnesses.
Old Nov 21, 2007 | 10:41 AM
MikeC5Vert's Avatar
Thanks so much!!!
I got 98 C5 so it got 5 wire but I currently used 85mm MAF so it got 3 wire converter.
-Mike
