does adding timing take away from top end
The point is, more timing isn't always better. The easiest way to find optimal timing is on a dyno. Make some changes, keep what works, and ditch what doesn't. Arbitrarily adding timing isn't going to do you any good.
That being said, running more than 29* before/after peak torque or more than 26* at peak torque will probably be too much and cause KR on a stock 98~00 f-body. 01~02 f-bodies don't seem to like more than 20~22* just before peak torque, 18~19* at peak torque, and topping off around 24* at redline. At least, that's what I've noticed being ~800ft above sea level. Change the altitude up and the game changes.
