emissions trouble
Old Dec 4, 2007 | 02:51 PM
stonemonk's Avatar
Default emissions trouble
hey guys, i have a 99 z28 w/ the egr, air, and no cats. I have used the diablo to tune out the codes necesary to get the engine light off and it seems that every time i do this after a few miles of driving the light comes back on the codes re appear. I have tried a few times w/ no luck, any ideas?
Old Dec 4, 2007 | 02:53 PM
horist's Avatar
it probably just clears them but doesn't disable them
Old Dec 4, 2007 | 02:59 PM
stonemonk's Avatar
the tuner says its suppose to shut them off, there is a seperate option to just clear codes
Old Dec 4, 2007 | 03:23 PM
2001NBMZ28's Avatar
Something's wrong, the later versions should permanently turn off P0420 and P0430, along with the EGR and AIR codes if desired.
Old Dec 4, 2007 | 03:31 PM
stonemonk's Avatar
it generally throws the egr code, i want to say its a p0410??
Old Dec 4, 2007 | 03:59 PM
2001NBMZ28's Avatar
P0410 is an AIR code, maybe P0401? - that's EGR. I read your first post to state you still had AIR and EGR, just no cats. It should still turn if off for you though.
Old Dec 4, 2007 | 04:21 PM
stonemonk's Avatar
my bad, i meant to put i deleted egr and air, and did a search for all the codes that needed to be off and turned them off through the diablo, and i still get egr, it could be 0401, i will double check that tomorrow, but it seems no matter what i do they continue to come back?!?!
Old Dec 7, 2007 | 05:03 PM
stonemonk's Avatar
well i got it to pass, however after i left the light came back on. The code is the 0410 code which is the air code that has come back, i guess it doesnt really matter now that i passed, i would like to get it to stay off though.
Old Dec 7, 2007 | 05:26 PM
2001NBMZ28's Avatar
It should turn it off, I'd contact diablosport or post on their forum.
Old Dec 8, 2007 | 04:45 PM
stonemonk's Avatar
thanks
