Log Works vs. HP tuners
Try grounding the LC-1 to the engine block, and try again. I have mine grounded to the passenger side head, and the XD-1 gauge and HPT agree at all times, 100%.
Can you compare the raw voltage output between both? Once upon a time, I set my LC-1 to output a fixed voltage for all AFRs (you can program it to do that if I'm remembering right)...in HPT, you can log raw voltage input, and let it run in a histogram to show you the overall average voltage.
If you tell the LC-1 to output 2.5V for all AFRs, and HPT reads 2.5V in, then you don't have a voltage offset problem.
Try that and let us know what you find. It could be something as simple as a miscalibration in your logging software...
The LC-1 is very sensitive to how it is wired to your car, and there have been a lot of failures due to improper install.
