IAC and RAFIG
Old Dec 15, 2007 | 08:54 PM
DaddySS's Avatar
Default IAC and RAFIG
If I adjust my throttle stop because my IAC steps are too low (17 warm), will I need to redo the rafig or is the desired airflow unchanged by IAC steps?
Old Dec 16, 2007 | 11:51 AM
P Mack's Avatar
17 is not too low for a fully warmed up engine with headlights, ac, radio, etc all turned off. If you do change the throttle stop you will have to change your idle airflow tables.
Old Dec 16, 2007 | 06:58 PM
DaddySS's Avatar
OK, thanks for the response.
