97 C5 ATI 9lb.-P1518, P1514, P1571 - Reduced Engine Power
Going above 4K rpm's causes the PCM to throw said codes and floods the motor with fuel, pulls timing, and generally makes the car run like chit ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
It seems to "re-set" when I shut her off and start her again??
Mods: '97 Vette with MagnaFlow exhaust, no cats, 38lb. injectors, and running an ATI D1SC with 9 lb. of boost.
I deleted the codes but the pcm does the same thing above 4K.
It appears to be some sort of safety feature from GM. How do I go around it?
I fixed the Lterms and they are fine on part-throttle driving but it doesn't change what happens above 4K rpm's![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Any help? Thanks fellas!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
