Running way to lean in cold open loop. How do I fix it?
Another consideration is the injectors. If you do feel that it is lean, you are going to have to increase your minimum injector on time and add the correct values to the ow pulse width on time table. What happens is with big injectors, they cannot respond fast enough at low pulsewidths and will just simply not open everytime. This sucks to deal with, but once you figure that out, it is easy to get around it.
I redid some of his tune to get him started. From there he should be able to tune the VE and get it dialed in.
From monitoring EFI-Live's forums I have found not every variable is used by GM in a particular OS.
I am def going to try that myself.
If it gets all the command fuel ratio from the cold open loop table, the why was it not running lean with no throttle?
At idle I have 14.xx fuel ratio and part throttle It would jump to 18.xx-20.xx???
Thanks
Figure 1: Raw difference from Stock VE compared to your modified VE.
Each of these cells represents the difference ( Modified - Stock). Not %. Just raw difference. The stock file was from www.holdencrazy.com. This is generated by loading the stock tune for comparison vs your tune in EFI-Live.
What looks wrong is the raw difference is flat. It is more than stock but entirely flat. They couldn't of tuned cell by cell and ended up with the same shape if you did heads and enlarged your bore. Just not possible. Given that... I believe what they programmed could never match the true demands of your engine....besides your cold start up problems.
Because the VE isn't correct even if you put in the correct AFR it still can't generate that AFR. That is why you are ok at idle and lean under load. Those heads surely flow more under load than stock so I don't think a flat adjustment to the VE table will work!
Have you loaded up the file provided by Ed and has it helped? With the corrected AFR table, displacement, and VE you should be much closer. I believe you will not be able to resolve all your problems with only one thread. So don't worry.
I need to tune the ve. it looks to me like he changed the whole ve table by a percentage. Still no one has a answer for my original question?
I will post the tunes and logs If its ok With Ed.
So if I command a 12.2 (1.2) it multiplys the ve by 1.2?? Do I understand that correctly?
Say the ve # is 20 To command a 14.63(1) it would use 20??
Say the ve # is 20 To command a 12.2 (1.2) it would use 24??
Is this correct??
BTW, you still have the MAF enabled, so you really arent tuning in SD yet. You'll need to disable that and then dial in the VE.
As for Auto VE and idle, you may have to play with the VE values at idle to get it to idle nice, and not worry about the WB readings.
As far as PE and its effect on A/F, you shouldnt even be worrying about that right now, as while tuning the VE you should be staying out of PE. You may want to set the eq, ratio to 1 up to like 4000, and/or set the TPS enable to 100% up to around 4000, that way it has no effect while you're tuning the VE.
The funny thing was, the 2 VE table were different, but neither one was close to being right.
Oh. I wasn't targeting you as I have no doubts about your tuning abilities. It was just a generic explanation of why the car was behaving as it is.
I subsequently set up a SD tune, so he could go out and start to dial in the VE.
Whats the proper order to tune it in??
Setup injectors, Ve table, Maf, spark, ????????
