I got it on video
They hooked my up with EFI Live, a LC1 wideband with gauge, for about $700-$800 Best money I spent so far!!
Compaired to heads and cams this it cheap!! Just my 0.02
Well it's running fine now and I'll start saving some $$ for EFI Live and a wideband. I think we'll get a wideband first as my brother is building an old school motor and we can use it to jet his carb.
I'd love to have the software to play with this. I don't know exactly what the issue is, but I love this kind of stuff. I work on elecrtrical controls for a living and love challenges. I think Jesse did a great job and now I really don't know if I have an input problem, but I don't know what inputs could be causing this. I've swapped the O2s and the TPS reads 0% during a high idle event. I don't see the IAC being at fualt for such an intermitant event either.
I like the idea of tryign to swap the tune to another PCM as it could perhaps be an issue with the PCM that rears its head when the temps go up? I'll call Jesse and see what he thinks?
Man I want tuning software!!!
I'm going to try and run with the IAC unplugged and see if the problem stays away?
In the meantime, the dog and I are going to go for drive (in the truck) and take a few guns to go shoot the crap out of stuff...that always makes me feel better.
Jesse has a good point on the vacuum leak with respect to thermal changes. It was damn cold the last this happened so it could be a material contracting and allowing air in? Or, it may be a fault with the harware like a bad IC or solder joint in the PCM. I can't think of anything else...
I know I can't tune with it, but will it give me the visibility I need to look at my engine parameters and then work with a tuner to improve it? I believe this is upgradeable to the full tuning version.
Also, how much can I find out without adding a wideband input to it? I'll get one, but not right away.
Can anyone verify that you can pull and look over your tune with just the scanner and the free trial of EFI Live???
