O2 signal
Hey Guys
This is not exactly a tuning question, but I figured this would be a great place to get the right answer. How can I "splice" into my O2 narrowbands to access a signal? Can I splice the acual wire (and if so, what is the best method) or do I need to go to the PCM (It's a C5)
Thanks
Thanks
Here they are: http://www.jegs.com/webapp/wcs/store...57617_-1_10625
From what Ive reade, narrowband only tells you if it's rich or lean from the junction's setpoint. I think 450mv is like the setpoint and anything less or more is either rich or lean.
I KNEW you guys would know this. That looks like exactly what I need. I just didn't like "splicing" or "taping" into the O2 wire, and I sure didn't want to F - - _ up my PCM.
So to make sure I'm clear, if I have a 98 C5, I can get 182-109049, and plug it into my my existing plug and then into my O2 (Drivers side front) and use a solderless connector to hook up my lean switch.
Thanks again for the info!!
I don't know which one to get, I just came across these one night while looking for wideband stuff. What exactly are you going to do with it? If you're just looking for lean is there some sort of algorithm or hysteresis built in? I know just watching mine while driving they go all over the place from 50 to 900mv. Of course I haven't really been able to watch them while staying on the gas, this is while sitting on cruise control. If I keep my foot in it I kind of like to keep my eyes on the road.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I have one of the Dynotune lean cut off switches that shuts off the N2O if you go lean. It has a recommedation of what voltage to set it at, but I havn't gotten to the set up point yet. It actaully has a display that you can put in the cockpit, but I don't plan on trying to read it on a run since it would be in voltage anyway. I think it has a recall feature to check the leanest "voltage" during a run.
Thanks again
Thanks again
Thanks again
Thanks again
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
