Big Cam/Low Vacuum tuning at idle and part throttle?
What are you guys doing to compensate for the low vacuum(MAP) at idle and part throttle. A friend of mine has the ASA Racing cam and 30lb injectors and it is running pig rich at idle and part throttle. At first we put the correct IFR in for the 30lbers and it ran rich...so we lied a little and increased the table 10%. That did not work because it began to stumble when you would role into/stomp on the gas(too lean on initial hit maybe).
Anyway, I was just hoping someone could point us in the right direction from a tuning stand point. We have edit and atap so please give us some pointers.
Thanks
Josh
Thanks
Josh
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Have you adjusted timing? drilled the TB?Here are a couple good threadsHOT CAM INSTALLAND VE TUNING to read. Excellent info!!
Good Luck.
joel(Bink)
Good Luck.
joel(Bink)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
