mount wideband sensor
Old Jan 15, 2008 | 12:49 PM
texasheat's Avatar
Default mount wideband sensor
Where is the best place to mount a wideband sensor in the exhaust?
Old Jan 15, 2008 | 01:02 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
in the end of the header, before the actual exhaust
Old Jan 15, 2008 | 02:36 PM
BadgeZ28's Avatar
Were if you only have one wideband sensor?
Old Jan 15, 2008 | 02:51 PM
red83's Avatar
same place. it needs to be mounted were the cylinders merge into the collector. just make sure it is before the cats
Old Jan 15, 2008 | 06:16 PM
ChrisV 02 - Z28's Avatar
could you put it in the actual X part if the exhaust on my duals???
Old Jan 15, 2008 | 06:24 PM
red83's Avatar
the closer to the heads the better
