U1000/ ECT not working
Old Jan 17, 2008 | 08:15 PM
Bombguy99z28's Avatar
Default U1000/ ECT not working
No ECT.
ECT is seeing ~5volts, sensor has resistance so I don't think its broke, swapped it anyway, getting a U1000 code (but not an ECTcode).
Cleaned the PCM contacts with electrical cleaner stuff, checked the grounds (ECT is grounded to the PCM I think, I reached back and checked the grounds on the back of the head but I think more would be haywire if a PCM ground was not grounded).
Any ideas?
Thanks.
Old Jan 18, 2008 | 12:16 AM
fuseone's Avatar
maybe its in the wires. seems like high resistance in it. do you have a scan tool hooked up or somthing to see what the computer is see if you unplug the ect?
Old Jan 28, 2008 | 04:05 PM
I sorted it out. The return wire to the PCM was shorted somewhere. It was getting voltage to the sensor but nothing back at the PCM. I just ghetto rigged it, cut out the sensor and spliced new wires in.
It was weird because I didn't think a U1000 code would pop for the ECT.
