Please Help!! 403 LS2 Tuning
Theres too much timing in it in the low load areas, possibly contributing to the surge.
As for your logs, you dont have alot of the pids on that you should. I would turn on the short terms at least, and the 02s. That'll give everyone an idea of what the computer is seeing, and doing.
I redid some of it. Hopefully it works a little better. I failed the maf, and set it up to run in SD. If you dont know how to chart the A/F correction, or STFT vs VE, read up on it, and then start tuning the VE.
If it doesnt wanna run, you may have taken too much fuel out of the VE, if you were doing that with the maf enabled.
You may need to add some more back, and then drive it easy as you plot the fuel trim correction, or A/F correction via wideband.
Brian
Brian
Yes you can go full throttle tunung the VE. But the object is to stay outta PE because it skews the A/F.
Are you using your chart to plot the A/F correction?
