Bog off the line
- 26x11.5x16 ET Streets
- HD built 4L60E
- 3800 TC
- 3.90:1 gears
- 383 stroker making about 430 rwhp
- Original programming by MMS;
Torque management removed and other changes via LS1Edit
I also disabled Abuse Mode; torque and timing reduction
You then launch and the PCM was attempting to solve the lean fuel trims and now at launch are too rich.
Long term fuel trims are acted on by the PCM every ten minutes so when you launch your PCM is really functioning as what the conditions were up to 10 minutes ago.
Also depending on how the torque management was set to when you launch the PCM could be backing timing down when TM kicks in so that is another function of PCM that needs to be tuned.
