are these normal??
bank 1 is drivers side
bank 2 is passenger side
sensor 1 "pre-cat"
sensor 2 "post-cat"
p0135B H02S Heater Performance Bank 1 Sensor 1
p0405a Exhaust Gas Recirculation(EGR) Position Sensor Circuit Malfunction
p0530c a/c refrigerant sensor circuit malfunction
the first code is a problem some have when putting in longtubes means the 02 sensor isnt getting hot enough and needs to be moved up close towards the front of the car.
second code is normal when u remove your EGR
And third if you remove your A/C
the first is a mechanical fix, 2nd and third can be removed with a simple tune out using HpTuners, Efilive, Ls1Edit, etc.
