another check my tune
Also the car was tuned in mid 40's degree weather. I am running a LM1 wideband and when running the car it stays right on 14.7 cruising and around high 12's when i'm at wide open throttle. I wish i could be more specific but the roads have been terrible since i've bought the car and I haven't had much of a chance to really open it up for a good period of time to see what the wideband reads at WOT.
When I bought the car this was the tune loaded in the computer. My mods include:
236/244 duration, 112lsa, 579 intake and exhaust lift
243 heads (not sure if they are ported)
ls6 intake
60lb injectors
full exhaust
running in speed density
will be running a 125-150 shot Harris speed works wet in the spring
Thanks for any help
so just be aware of that when you do nitrous, but you have a wideband so it can be fixed. also, on the spray, i would start conservative and work your way up in either .5 or 1 degree of timing incriments.
Also with using my front wheel abs sensor for my speedo sensor this kicked my abs and parking brake lights on. I didn't want abs anyway. I've looked on the disable lights table and couldn't find anything i could disable to take these lights off. Anyone have any suggestions?
Also I have been doing some searching and was wondering if you can run the Innovate LM1 in the HP tuners program some how, or how are others checking there wideband readings against their tunes?
i had to add more fuel, but i only messed with the VE and MAF tables. and, i dont run speed density(i hate the idea of speed density) i just tune my VE from what i can without hitting PE.
