OBD1 scanner cant log into PCM
Old Feb 4, 2008 | 02:22 PM
Revelation Z28's Avatar
Default OBD1 scanner cant log into PCM
i bought a scanner a couple days ago to get a code thats tripping my SES light which will solve my dying on idle problem, and the scanner cant get into the PCM nor can it find any DTC codes ive tried wiggling the connector, and holding it different directions. anyone have any tips?
Old Feb 4, 2008 | 02:57 PM
foff667's Avatar
LS1TECH Sponsor
OBD1 you can gather codes manually, its been a long time since I've touched an obd1 fbod but check out thirdgen.org for info on their codes & how to retreive them.
-Bill
Old Feb 4, 2008 | 03:04 PM
2001NBMZ28's Avatar
If it needs power from the DLC port check your fuse that powers it, if it's like the LS1 cars it's the CIG/ACCY fuse. '93 was the last year you could flash the light manually to retrieve codes.
Old Feb 4, 2008 | 03:24 PM
Camaroholic's Avatar
'94 does not have power in the OBD1 connector (use a cig lighter or battery for that part), nor will it flash codes with a paperclip.
What scanner did you buy? Is it a smart scanner? If it's just a dumb code reader, it probably won't work.
Old Feb 4, 2008 | 10:11 PM
its the $199 scanner thats updateable. i forgot the name. here is is: http://www.partsamerica.com/ProductD...egoryCode=3389
so what would i have to do to power the DLC port? i know the cig fuse works because the lighter still heats up.
Old Feb 7, 2008 | 12:34 AM
bump.
anyone know how to power the DLC connector?
Old Feb 7, 2008 | 01:10 AM
fuseone's Avatar
just curious did you turn the key on but engine off postion. and see if that works?
Old Feb 7, 2008 | 04:52 AM
yep first thing i did.
Old Feb 7, 2008 | 10:43 PM
sreve's Avatar
although your car has a obd2 style plug it is not obd2. it is obd1 and the paper clip
trick will not work .
unless you have another car to use it on take it back and get your money.
they are commonly called obd1&1\2
Old Feb 7, 2008 | 11:26 PM
i have the 12 pin port. it came with a 12 pin OBD 1 cable for GM. the instructions say compatible with the 94-95 f body.
so if this thing wont work, how would i be able to get the code?
Old Feb 12, 2008 | 11:41 PM
bump for ideas. i probed the connector and got 5-7V. i dont know if the connector is in fact powered like camaroholic said. or how to power it myself.
Old May 11, 2008 | 12:28 PM
HALNAZZ's Avatar
I am having the same trouble with my 94 Z28. I bought a code reader and it says ynable to connect to pcm. Anybody got any advice?
