Please Help !!!misfire
this is a new motor if that helps.
could it be a bad PCM????
spark chain from plug to PCM. Coil packs & connectors,
plug wires, etc. are all in it. Might try using a "noid light"
or a multimeter to look for coil primary-side activity,
while running it ought to be some moderate-low voltage
(12V averaged down by the dwell angle) and all 8 ought
to read identically. A gross imbalance would point at
the PCM (or coil/harness short/open). Not the secondary
side, your meter will not take that well.
