very weird problem
Old Feb 6, 2008 | 08:11 PM
slvr98camaro's Avatar
Default very weird problem
hey guys.. first off, this is NOT a GM car, sorry if this is the wrong forum, but i know you guys are very smart when it comes to stuff like this, and it isnt brand related
first off, its on my friends car, a ford escort (its the mercury version i think) and the alternator died. They put a new battery in the car, and drove home on the remaining power and installed a new alternator.
heres where the problem comes in, it ONLY starts when a wire is plugged into the OBDII port, it doesnt matter if anything is connected to the wire or not.
as of right now, my friend unplugged the battery for at least an hour and that didnt solve the problem. He also said he checked the fuses and they all checked fine
any ideas on what it could be? the ford dealer took a look at it, but couldnt find a solution, and im having a hard time with people believing me that this is happening as nobody i have talked to has heard about this
thanks a ton for any help!
Old Feb 6, 2008 | 08:17 PM
displacementdan's Avatar
Ok, 1st of we need some info.
1. By doesnt start you mean doesnt turn over or just doesnt start?
2. The car worked perfectly well before the battery install?
3. Who installed the alternator? was the battery out when it was being changed?
4. What wire is unplugged in the obd2port and how did you come across unpluggining the wire? Do you have a diagram for the connector and the pins to verify what it is that you unplugged?
we need some more info to better diagnose this problem im sure that it can be figured out with a little trouble shooting.
Old Feb 6, 2008 | 08:19 PM
i have access to alldata if you give me vehicle specs i can look up the pins for ya to figure out what is what if thats what it comes down to. WE NEED MORE INFO
Old Feb 6, 2008 | 08:32 PM
i can answer a few myself
1. the car just keeps cranking
2. the car worked perfectly
3. my friend installed it, and the battery was unhooked
4. the wire that was plugged into the obd port was a scan gauge 2, there was nothing plugged in before, it was the first time it was ever used on the car. he isnt sure if he had it plugged in the first time he tried to start the car with the new alternator
also when he tries to start it the fuel pump stays priming when there i nothing plugged into the obd port
Old Feb 6, 2008 | 09:03 PM
so it only runs with the scanner hooked up? what modle is it? did the car run before you put it in after the alternator install? Check for the basics 1st any lights? Are you getting spark fuel? do this with the scanner out and then in.
Old Feb 6, 2008 | 09:04 PM
this is what it is: http://www.scangauge.com/
teh car ran perfect before the alternator
Old Feb 7, 2008 | 07:57 PM
Bill Bowling's Avatar
Found the problem yet?
Bill
Old Feb 7, 2008 | 08:15 PM
well an alternator and battery should have to effect on your car not running if installed correctly so its probably something with that **** ******* it up. Call a hotline or something see if anyone has simmilar problems as you. Only things i can think of if this is any help at all are...
1. check all our basics fuel spark ex like i said w/o that **** in there, you tried resetting the battery so the ecu should be reset. If you dont have fuel or spark diagnose why
2. It might be soemthign w/ that **** in the obd2 that lets the car bypass some type of security possibly reading that the key is in there and allowing it to run
3. You might possibly fried some type of module, have the dealership scan it and make sure all the modules are communicating w/ eachother
report back w/ more info im really curious to solve this problem for ya
anyone else have any input?
Old Feb 7, 2008 | 08:18 PM
Posts: 2 Re: 1993 Mercury Tracer - Ford Escort-Will not start-has good battery
I had checked other sites and found that technician's said they replaced the ignition switch,not the lock. A $20 to $30 part in your steering column
They said this fixed the No Start problem. They said get one from ford since aftermarket parts were not as good. Must have been a ford Tech that posted it.
It could be the relay switch for starter on the firewall or the solenoid could be bad.
I am very doubtful it is the alternator but I'll check that tomorrow with my digital meter also.
I have seen this problem with many tracer and escort cars.. hopefully the ignition switch fixes it.
If we can post link's to parts on websites with photo of the Switch,I would post it here. Can we? yes or no? It would help in identifying the part for other people.
Update..... I got the switch out and took it apart and one of the plastic rods inside was melted that pushes the points down and went to the starter wire, blue and black wire.The points for that were also melted down lower than the other 3 also. I tried cutting off a toothpick same length as the other plastic rods and put it back together with that for testing purposes and still no start. I will have to buy a new switch from a site online for the $23. Local parts stores want me to buy the whole key switch mechanism for $100. Blahh. no way. I tested the power on the 2 black coming in to the switch, and they have power so no fusable links bad.
Old Feb 7, 2008 | 08:21 PM
check that^ but idk caz it does start it has to do IMO with some security setting being bypasses by the connection in the obd2 im gonna keep researching
Old Feb 7, 2008 | 08:31 PM
you seem to be forgetting the car starts and drives fine when the wire is plugged in
ill give my friend a call and see what he says, but thanks a ton for the help so far
Old Feb 8, 2008 | 10:23 PM
it runs u want the scanner **** it lol
