surge/bucking 2500 rpm and lower in all gears? Car was just tuned.
I have a 99 6-speed with a 413 ci. with a 251/257 dur.@600 Lift 114 LSA cam,Stage 3 ported heads w/ 2.08 intake 1.65 exhaust valves, oz700 clutch, LS6 MAF, LS2 ported intake, LS2 ported 90mm TB, 42# inj., SLP long tubes, X-pipe and borla cat-back. I just dyno tuned the car today. The problem im having is a low RPM surge around 2600 rpm and lower, in all gears. The problem was present before the tune and is still there, the tuner did all he could to fix the problem with no luck. Could it be something other then cam surge? After 2600 rpm the car is a beast and runs great. Any help would be great.
Plus the car has a really hard time starting up. It threw up a cam position sensor code. any ideas? And were is it located?
I assume that your running ls2 style front cam position sensor. If so some extenstion harness the ones i've used the two outside wires need to be swapped. This will cure the hard starts and code . As far as the surging goes that is a fairly large cam so you may have to live with some surging. Are you running maf or sd.
Its on the front of the timing cover.
I have the same problem you do with almost identical specs (418ci, 251/258 cam at 114lsa) and the things is an absolute dog under 2500rmp but after that it's a beast. Did you ever figure it out?
What is the ICL? What is the compression? Is it speed density tuned?
The short block I bought was assembled by a local reputable builder and he talked with compcams to spec the cam, I'm not sure of the ICL. It was tuned by the same guy, but it wasn't SD tuned, I'm running the larger 85mm MAF.
