Lm-1 - Hp Tuners With Eio Help!
that does. You're looking for a 0-4V signal. You can program
the LM-1 to put out a fixed 2.000V and then see where that
shows up. Then you can switch back to the AFR function
when you know what's what. Might have to get into the
LM Programmer or the evil LogWorks to make sure the
output you're looking for isn't disabled or something. The
LM-1 I have loses its mind when the 9V battery runs out.
You have LM-1 ground tied to EIO ground I expect. What
is the power source for the unit? With the two unconnected
measure the voltage (DC & AC) between LM-1 ground and
EIO ground. Does it look significant relative to the signal
you'd expect to see?
whatever the leakage & noise "tell" it. If you jumpered
the unused ones to the connector ground they should
quiet down. Presuming there isn't some other problem.
