Is this correct for SVO 36lb injectors
I'm tuning my svo 36lb injectors and here's what I came up with. 36lb at 43.5 psi
Map/injector flow 0/6.96 5/7.00 10/7.04 15/7.09 20/7.13 25/7.17 30/7.21 35/7.26 40/7.30 45/7.34 50/7.38 55/7.42 60/7.46 65/7.50 70/7.54 75/7.58 80/7.62 I just want to double check to make sure I figured it out right.
Dumb Ass Vette Moderator
Re: Is this correct for SVO 36lb injectors
Those flow number look to be in the ballpark. Just remember that they are ballpark and can vary. Tuning for my 30# took some tweeking of the Injector Flow Rate table and also the PE vs RPM to get ym LTFT and A/F ratio right.
