can someone help me please
Old Jul 17, 2003 | 12:40 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
Default can someone help me please
i had just ordered the qmp turbo kit and they send the kit but you have to send your original pcm out for programing and i dont have a place to store the car while it is out ,what i was wondering is that if i sent it out for programing and it was programed for #42 injectors would i be able to drive it only 1 mile to the shop on stock injectors and maf.
Old Jul 17, 2003 | 04:14 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: can someone help me please
You would not be able to swap the injectors before then?
Could you borrow a MAF T? You can use it to add fuel with the base setting.
Old Jul 17, 2003 | 05:08 PM
i could switch the injectors but i dont know what else they do programing it,i was just curious because my shop is only like a mile away but i suppose i could switch the injectors and maf here and then drive it i just dont know exactly what else they do to the pcm as far as other things to compensate for the turbo thank you for the help
