98 Tune
Old Mar 2, 2008 | 09:27 PM
tee-boy's Avatar
Default 98 Tune
What's the truth about tuning a 98 PCM after heads/cam swap? Can a reputable shop get the tune done?
Old Mar 3, 2008 | 12:02 PM
Doc's Avatar
Doc
A good shop can get the H/C job done with the 98 pcm.
If you upgrade your pcm you will be able to run custom software to control
N20 at the flip of a switch- like having two tunes in one pcm (Read-no pulling over, re-flashing, just push a button on the fly...).
You will also be able to run a 2 or 3 bar MAP sensor for boost if you choose to go forced induction later on.
Old Mar 3, 2008 | 12:13 PM
foff667's Avatar
LS1TECH Sponsor
The 98 pcm can handle a 2 bar map sensor with our software package & as stated any capable tuner should have no problems tuning your vehicle using the 98 pcm.
Old Mar 3, 2008 | 12:50 PM
tee-boy's Avatar
excellent. thanks. What are the differences b/w EFI Live for 98 and 99 and up, if any?
Old Mar 3, 2008 | 12:51 PM
tee-boy's Avatar
What are the differences b/w HP Tuners for 98 and 99 and up, if any?
Old Mar 3, 2008 | 03:18 PM
foff667's Avatar
LS1TECH Sponsor
98's don't have a 1 bar or 3 bar custom os available as compared to 99+ pcm's do with our software, but if you plan on using the stock operating system there really isn't much of a disadvantage at all.
Old Mar 4, 2008 | 08:03 PM
Tootall's Avatar
can you do RTT with a 99 PCM ?
Old Mar 4, 2008 | 08:28 PM
mikey's Avatar
LS1TECH Sponsor
I just did a 98 with a large cam and TFS 215 heads. Runs perfect.
