ls1 edit 8.1l injector values
Old Jul 21, 2003 | 02:44 AM
METAL MAN's Avatar
Default ls1 edit 8.1l injector values
Ok, I have a 5.3l 99 Silverado with a whipple (7lbs.). I installed 8.1 liter injectors and now need to dial them in with ls1edit. I can't figure out what values to put into the excel formula found on ls1edit@slowcar.net . Stock numbers were 2.74 across the table on the stock tune. I think the 8.1l injectors are 29-30lbs. fuel pressure is stock.
Old Jul 21, 2003 | 09:29 PM
METAL MAN's Avatar
Default Re: ls1 edit 8.1l injector values
help
Old Jul 21, 2003 | 09:43 PM
XLR8NSS's Avatar
Adkoonerstrator
Don't worry about that excel formula, I believe it's for Fbodys which have a different fuel system.
For the injectors try a value of 3.71 across the table. That should get you close but, I'm not sure of the exact size of those injectors.
If you post this in the truck performance section I'm sure you'll get a better answer. A few guys in there have ran these before so they should be able to help.
John "Truck Forums Director"
Old Jul 21, 2003 | 09:44 PM
NoGo's Avatar
There are a couple ways to calibrate your injectors.
Setting your injectors is not an exact science, so you are going to need some sort of scan tool to check your edit.
You will have to monitor your Lterms for both banks.
The object is to set your injector flow rate table so that your LTerms are roughly -5% at an idle (it doen'st have to be exact, just in the ballpark).
A quick percentage calc will give you some good starter numbers.
(New Injector lb/hr) / (Stock Injector lb/hr) = Number
Multiply your Injector Flow Rate table by the number you just came up with.
Load the program and start your car. Check your LTerms.
If your LTerms are positive shift the Injector flow rate table down in 2% steps until they go slightly negative.
If your LTerms are waaaay negative shift the injector flow rate table up in 2% steps until they are slightly negative.
Good Luck,
Kevin
Old Jul 22, 2003 | 12:31 AM
METAL MAN's Avatar
thanks guys i will try this out
Old Jul 22, 2003 | 09:33 AM
NicD's Avatar
7 Second Club
Let me know when you want me to tune it.
